How build dll with labview 8.2
Hi ppl i need to construct one dll n labview 8.2 but and don´t found the Build Application or Shared Library (DLL). in the menu tools?
it is possible construct a dll in labviwe 8.2!?
Message 1 of 12
(4,069 Views)
The application build part of it is included in the Professional Edition of LabVIEW. Which edition do you have? If it's the Base or Full, you won't have it (see here), though you can purchase it separately.
Message 2 of 12
(4,058 Views)
i have a labview profissional developement system 8.2.1!i thinks that is is possible make a dll but i dont find this Tools»Build Application or Shared Library (DLL)
i see this in this site: http://zone.ni.com/devzone/cda/tut/p/id/3063
Message 3 of 12
(4,051 Views)
OK. Needed to check the edition first. That link doesn't apply to LabVIEW 8+. In LabVIEW 8 you need to create a project in order to build an executable. Check the documentation for LabVIEW 8. You first create a project and place your VIs in it, and then create a build target. It's all in the documentation.
Message 4 of 12
(4,048 Views)
thanks for all repply, and attention. but my problem is that i dont have the documentation wihe me because i´m start to work with labviw in my university.
if you can find some documentation you can send me!?
Thanks a lot
Message 5 of 12
(4,044 Views)
The documentation should have been installed with LabVIEW: "Help -> Search the LabVIEW Help".
You can also find it on this web site. I'm sure you're more than capable of performing a search now that you're in college. Smiley Wink
Message 6 of 12
(4,043 Views)
> &nbsp;
> Thanks
To build a shared DLL with labview you need Application Builder.
Application Builder is only included as a standard item with the
Professional version of Labview. National Instruments sells
Application Builder as an add-on for use with either the Basic or Full
version of Labview. The cost is US$1,000.00. Instead of using a
shared DLL to communicate with Labview from an external application I
suggest you use Activex. Activex is included as a standard item with
the Student, Basic, and Full versions of Labview.
Howard
Message 7 of 12
(4,034 Views)
> i see this in this site: <a href="http://zone.ni.com/devzone/cda/tut/p/id/3063" target="_blank">http://zone.ni.com/devzone/cda/tut/p/id/3063</a>
Two suggestions
Double check and make sure you have the Professional Development
version of Labview. Do this by starting Labview ant then clicking on
"Help" and "About Labview" The "About Screen" will tell you what
version of Labview you have installed on your computer. If the "About
Screen" says you have the Professional Development version of Labview
installed on your computer and you don't see "Application Builder" in
the "Tools" menu then I suggest you talk to your local National
Instruments Sales Representative to get help.
Howard
Message 8 of 12
(4,026 Views)
We have a tutorial on the NI.com, they explain how use application builder for LV 8.x :
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
You can found on ni.com the LabVIEW 8.2 help :
http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/building_a_dll/
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
Message 9 of 12
(4,002 Views)
thanks all user i will try do this! thanks a lot Christophe S.
Message 10 of 12
(3,997 Views)
