How can I Change data in a type def control containing a Xcontrol with a local variable
Hello
I made a Xcontrol and I inserted this control in a type def.
When I want to change the control's data with a local variable in a VI, the VI change nothing. The change of data isn't perform
How can I correct this issue?
Thanks for your help
(2,666 Views)
Accepted by topic author FJNI
What's your LabVIEW version ? Do you have a simple example program which demonstrates this behavior ?
I found another discussions related to your issues with Xcontrols:
updating type defs in Xcontrol Facade
No Data Change event generated for a XControl in a Type Def
XControl facede.vi
Hope this helps.
Steve M.
(2,638 Views)
