How can I abort my vi?
I have a sub vi(pop up window) which is stuck in a loop and it is called when my main vi starts. I can't seem to be able to edit either vi - just to exit Labview!
(2,869 Views)
Have you tried "CTRL ."?
(2,869 Views)
Hey Shan Pin Koh, thats handy to know - better than my other idea. Thanks for sharing it. Doug
(2,869 Views)
Great! Thanks for sharing it Shan!
(2,869 Views)
It sounds like when the subvi opens, it runs indefinitely.
If every time you open the vi to edit it, it runs - you can open a new VI and insert these bad VIs as subvi, then you can open them for editing.
Then edit the bad VIs by changing the True/False control at its While loop run control. It might have a forced True making it run continuously when opened - in which case you can change to a False to allow only 1 loop.
Another way to try to stop a free-running VI, besides Ctrl/alt/del is to attempt to turn your highlight mode On - between loops (its just a matter of luck though), this allows you the extra second to then abort the vi.
Good luck with it, Doug
(2,869 Views)
