How can I access Raw frames coming in my Ethernet port
I am working with a RT system running in Veristand 2011 SP1 on PXIe-8133 controller. The OS is Phar Lap.
I would like to know the procedure to access the Raw TCP frames coming in the PXI Ethernet port.
I have used the Wincap solution for the Windows based application. But when I used the same vis in a Custom Device, the project is not getting deployed. It looks like wincp dlls are not supported in Phar Lap.
I would appreciate any help towards this problem. I am kind of stuck in this issue.
Thanks and Regards,
Mirash
Coding is a combination of intelligent and creative work - someone
Message 1 of 1
(2,437 Views)
