How can I access the HP VEE data transferred to LabVIEW through Active X?
When I write Data in Excel Cells through ActiveX it is clear that you address each cell. But to which addresses do I transfer the data from HP Vee to LAbVIEW. There are no specific cells I can address. I am talking about a direct Data Exchange from HP Vee to LabVIEW with ActiveX.
Thanks for your help.
(2,776 Views)
Dominik,
I am not an HP Vee expert. However, you will want to transfer the data directly to a LabVIEW VI. You will need to create a VI that accepts the data coming out of HP VEE.
You could also use DataSocket to transfer the data. This may be an easier method. You can use the DataSocket ActiveX control in HP Vee to write data to the server, and then read that data back in from the LabVIEW side using DataSocket functions.
Randy Hoskin
http://www.ni.com/ask
(2,776 Views)
