How can I achieve control loop timing faster than 1ms in DIO series ?
I'm planning to use PCI-DIO-32HS for making relevant digital signal going to some D/A chip. For my application, microsecond order time interval between each digital outputs is indispensible, but LabVIEW has only 1 ms resolution wait time VI.
Is there any VI in LabVIEW Real-Time that meets my need?
(2,751 Views)
Yes!
LV RT running under Pharlap can use hardware timing on the order of the 1 microsecond.
Ben
(2,751 Views)
