How can I add date-range search and pagination to a JSON-based table in LabVIEW?
I have a JSON dataset that I parse into clusters and display in a table. I am using LabVIEW 2023 Q3.
Now I want to add:
  1. Date-range filtering (example: show only data from 11/12/2025 to 11/13/2025)
  2. Pagination (e.g., 20 rows per page)
My DATE field in JSON is a string like "20251112".
What is the recommended way to convert this into a timestamp, filter rows by date, and then display only the selected page using Array Subset or another method?
VI attached.
Thanks!
(215 Views)
Hi hwkim,
  • Use ScanFromString to convert the string into a timestamp. See the explanations for the %<>T format code in the LabVIEW help!
  • Use InRangeAndCoerce (in an autoindexing FOR loop with a conditional output tunnel) to filter by timestamps…
  • ArraySubset is just fine to get a subset from an array…
(210 Views)
Hello, GerdW.
I really appreciate your feedback. I revised my code based on your comments, but it’s still not working as expected.
Could you please give me a bit more direction or some additional hints? I’ve attached my revised code for reference.
Best wishes,
Hyunwook Kim
(100 Views)
Hi Kim,
Did you notice the signature line in my message?
(I prefer LV2019. Please downconvert your VI and attach again: File menu -> Save for previous)
(83 Views)
I really appreciate your time and help.
Can you please open the vi that I just attached?
(56 Views)
You made a few errors that kept things from working, but you were close! Fixed version attached, I think it does what you're looking to do. As mentioned before, Array Subset will let you paginate this.
(51 Views)
