How can I add pages to a tab control programmatically?
I would like to know if there is any way to add pages to a tab control programatically.
(3,997 Views)
Tabs are like to enums so I dont think you can update them at runtime.  You can however make extra taba and hide/show them at runtime.  What are you trying to do, maybe there is a work around (subpanels, dynamic vis ...)
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,993 Views)
I do not think you can add/delete pages to a tab control at run time. These are only edit time features.
A work around would be to create all the pages you need, hide the pages, and then make the pages visible at run-time as needed.
What are the requirements of your application?
(3,990 Views)
I have to show some information from n sensors. The number of sensors will be determined at run time and for each sensor there will be a page from a tab which shows some indicators and graphs. I think I wold have to create extra pages and make them become visible at run time according to my needs, as you suggest. Thank you for the answers.
(3,982 Views)
There are some work arounds one is to think of ways to reuse a finite set of controls instead of tabs (reconfigure the look depending on the selected sensor).  Are all the sensors the same?  Is there a maximum number of sensors?
Paul
Paul Falkenstein
(3,936 Views)
Also, if you're using a tab control, you can only view one sensor at a time, so why not use a subpanel, have all your sensor display VIs running dynamically, and insert the proper VI upon user selection?
edit - also, if you have an unknown N number of sensors that are putting out similar data, you can make the display VI into a .vit and call instances programmatically.
Message Edited by JeffOverton on 05-02-2008 10:25 AM
(3,922 Views)
