How can I add plot from diferent file?
I have plots on graph from file. How can I add another plot? I wont to
compare one of this plots with plot from different file. I try to use
table but date dissapear when I start again my program.
Thanks for help
Darek
(3,784 Views)
If your problem is that data is cleared after rebooting your program, you can make values default.
If not, i really don't understand the question.
Good luck
(3,784 Views)
Yes, I now about it, but how can I leave that data on graph and add
another data (in order to compare plots from two different file).
Default data is cleared when I read new file.
Is it a method to read data from different file and put it on the same
graph?
Thanks for help
Darek
(3,784 Views)
What you need is a multiplot graph, wire the two arrays of clusters of x and y values into a cluster, or wire the two clusters of arrays of x and y into an array, and wire any of them to the graph indicator. You'll get both plots in the same graph at the same time.
Hope this helps
(3,784 Views)
Thank you for answers, but my problem is a more complicated. I read data
from a file and get four plots in the same graph and.... next I want
leave this data on the graph and update graph with the new data (for
example: I'd like to update graph with the new two plots from different
file in order to compare with four plots witch I read before).
Thanks for help
Darek
(3,784 Views)
This example may be useful.
Dariusz Downar wrote in message
news:3B402152.471F3DD9@ien.gda.pl...
> Thanks for help
> Darek
[Attachment Untitled 1.dat, see below]
(3,784 Views)
Sloppy of me. Rename the .dat attachment to .vi to run this. The featureless
oval to the right is a pushbutton.
Craig Graham wrote in message
news:3b404475@newsgroups....
(3,784 Views)
