How can I add text to a progress bar?
I want to be able to add text to a progress bar that updates with status as the bar is progressing.  I can’t seem to find any property nodes for this.  Any ideas on a clean/easy way to do this?
Message 1 of 12
(5,804 Views)
use a string indecator to display what state you are in
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 12
(5,798 Views)
I had considered this but I don’t like the look and feel of doing it this way.  Perhaps a better question would be is there a way to make the container/border of a sting indicator transparent (like a label) so I can overlay the status text in the progress bar?
Message Edited by dubs on 11-30-2009 03:35 PM
Message 3 of 12
(5,788 Views)
You can make the string indicator transparent with the paint tool (View>Tools Palette).
What kind of text do you want to display?
Message 4 of 12
(5,779 Views)
Accepted by topic author dubs
Like this?
Jean-Marc
Message 5 of 12
(5,774 Views)
Yes, you can customize your control with the tools palette and go to set color and change it to the T for transparent
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 12
(5,771 Views)
J-M wrote:
Like this?
Jean-Marc
Perfect!  Thank you much.
Message 7 of 12
(5,767 Views)
That's a pretty tedious way to display that. You don't have to select text display in order to show 'Progress: x%". The normal digital display will do this with a format statement of 'Progress: %d%%'.
Message 8 of 12
(5,764 Views)
True, but I want to display status text, not just % complete.
Message 9 of 12
(5,761 Views)
You can also use a .NET container and .NET control; I used to have an example of this somewhere...
Message 10 of 12
(5,750 Views)
