How can I amplify audio signals from wav file?(gain control)
I want to develop an audio equalizer using labview. How can I control the gain of the audio signal (amplify) using labview vis.
(4,454 Views)
If your audio signal is in form of a numeric array or a waveform cluster, to amplify it, just muliply it with a numeric value Smiley Wink
like in this VI
Regards
Dev
(4,448 Views)
For some reason I'm not being able to use the multiply function to control the gain of my audio output on this VI (when I try to attach a constant value to the multiplier, it displays some sort of array control). Any ideas?
(4,385 Views)
LabVIEW 7.1 is currently installed on my system, so could not open your vi
could you please post a picture of your block diagram??
(4,370 Views)
Greetings!
       You should be able to pull up a numeric constant from the numeric pallete in the block diagram and wire it to the multiply. Please refer attached image. It willl result in a 1 D array of waveform.
Thanks and hope this helps
Avi Harjani
(4,359 Views)
