I am collecting simple BER data from a communications receiver for modulations such as PSK, CPM, etc. The data looks good but has the usual measurement noise, which I would like to spiffy-up for customer presentations.
I have tried virtually all of the vi's in the LV Fitting palette, with little or no success. One of the NI AE's provided me with a GP Fit approach, but it has problems when you introduce error. I have attached a vi which demonstrates this, and also shows an attempt on my part to use the Least squares vi, with various functional estimates of the erfc vi. The vi also includes sample data.
I see MatLab (and possibly Wolfram) has a function specifically for BER smoothing, but NI doesn't, as best I can tell. I feel certain that one or more of the LV fitting vi's can be coerced into working with the correct parameters - but so far I can't find them!
Has anyone tackled this problem with good results?
One other thing - has anyone else noticed that the formula used by the LV erfc (complementary error function) is *not* the standard model used for BER/radio communications applications?
Appendix B of Digital Communications by B. Sklar gives the conversion:
Q(x) = 1/2 erfc (x/sqrt(2)), where erfc (x) is the LabView vi block.
Mark
