How can I automatically create the files with serie-name?
Hello, Everyone,
I have a question again.
How can I automatically create the file with a serie-filename?
e.g. I have a program, it will repeat 5 times, and every time it will create a bmp-file, and I want to let this program automatically save these 5 files with a Serie-filename like File001.bmp, File002.bmp, .... File005.bmp.
How can I do it?`
Thanks a lot.
Regarts,
Johnny
Message 1 of 9
(3,640 Views)
Hi Johnny,
use a "format into string" with "File%04d.bmp" as format code and wire the loop iteration count to it's input. The result will be the filename...
Message 2 of 9
(3,638 Views)
can you send me an example for that?
Thanks.
Message 3 of 9
(3,612 Views)
Hi
See the example code for the above suggestion...
Regards
Message 4 of 9
(3,591 Views)
Hi Deepu,
you should avoid using string functions to build full path! Use path constants ("C:\") and a "build path" node!
Message 5 of 9
(3,582 Views)
Thanks Gerd, here is the updated pic...
Message 6 of 9
(3,576 Views)
Hi Deepu,
one more comment Smiley Very Happy
The format code should be "%04d" to get leading zeros and have filenames with same length...
Message 7 of 9
(3,567 Views)
Oh yeah!...
Thanks again... hahaha
I was actually searching for something while drawing that code... silly me...
anyway, I think since your comments are there, I will not post one more pic (to avoid more mistakes hi hi...).
Hope those looking for info will read the comment as well...
Regards
Message 8 of 9
(3,562 Views)
thank you for your reply, it works perfect, thanks a lot.
Regarts,
Johnny
Message 9 of 9
(3,551 Views)
