How can I average images during acquisition with a NI PCI-1407 frame grabber?
I am using a NI PCI-1407 frame grabber to acquire images of a standard video camera. How can I average a user-specified number of images in order to improve the signal-to-noise ratio? Is there a Labview code for this?
Message 1 of 8
(4,040 Views)
I am not entirely sure what you mean by averaging. To average numbers, you add them together and divide the result by the count of numbers totaled. You can add images together, but I am unsure how you would divide the result by the count of images.
Bob Young
Message 2 of 8
(4,029 Views)
Hi Jan,
could you send us more information about your question ???
Regards
Diego M.
Message 3 of 8
(4,007 Views)
you can use NI's Vision Module to average images. There's a library of arithmetic operators that allows you to do that on images (pixel to pixel operations such as add, subtract, etc...).
Besides that, another approach could be to use filtering single images (i.e. lowpass) to get a similar effect.
There's an example called Image Averaging Example which shows the first approach.
Jorge M.
Mensaje editado por Jorge M.
Message 4 of 8
(4,003 Views)
I have found the averaging example code you mention and got it working.
thanks a lot,
jan
Message 5 of 8
(3,974 Views)
another user already provided me with a solution, an example code to average several images. thanks anyway.
Message 6 of 8
(3,972 Views)
Message 7 of 8
(3,971 Views)
Hi Jorge,
Actually I want to do the same thing. I will save number of images and I want to average them to get a better resolution. (SNR) But I couldn't find the tool that you said. (Adding, subtracting, etc) Could you please help me about it? I have also attached the Labview code for grabbing images.
Many thanks,
Ali
Message 8 of 8
(3,355 Views)
