How can I build a dll containing a callback function ,the callback function is used in CVI.
HI
Case is that LABVIEW receive external data and produce a interrupt ,then pass data to CVI.
Can I build a dll  containing a callback function ,use the callback function in CVI. Or there is a better way?
THANKS
Message 1 of 14
(6,394 Views)
We need a lot more information about what you want to do and what you have done so far to be able to give any useful information here.
Most likely you do not want to use callback functions at all.
And why would you want to do the data acquisition in LabVIEW to create a DLL of it to be used in CVI, instead of doing all in CVI directly??
Message Edited by rolfk on 11-17-2009 08:10 AM
Rolf Kalbermatter  My Blog
Message 2 of 14
(6,384 Views)
http://zone.ni.com/devzone/cda/tut/p/id/8503
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
Message 3 of 14
(6,377 Views)
rolfk 写:
The data acquisition is done on PXI-7842 ,it must work in LABVIEW . Then other task has done in CVI. So,  LABVIEW(getting data) --> CVI(processing data) .
Message 4 of 14
(6,362 Views)
What Rolf is trying to say is that there is no reason to use LV to collect the data and pass to CVI when you can just simply do the data collection in CVI. If LabVIEW can do it then CVI can do it the exact same way.
Joe.
"NOTHING IS EVER EASY"
Message 5 of 14
(6,354 Views)
Joe_H 写:
I use PXI-7842.  Can I  operate it with CVI ?
Message 6 of 14
(6,326 Views)
If you can run it in LV then you can use it in CVI. The daq driver is the same, it is just the interface in which it is used. You can use it in LabVIEW, CVI, C++. Whichever you prefer.
Joe.
Message 7 of 14
(6,321 Views)
Joe_H 写:
I need operate FPGA of PXI-7842.  Can CVI do it ?
I will receive external data through programming FPGA, then translate data to CVI for other task .
External data will arrive at any time . LV must buffer external data, then tell CVI  data ready to take away.
And I do not want to use the query method with CVI always.
帖子被coolfire在 11-19-2009 10:25 AM
时编辑过了
帖子被coolfire在 11-19-2009 10:26 AM
时编辑过了
Message 8 of 14
(6,311 Views)
coolfire wrote:
I need operate FPGA of PXI-7842.  Can CVI do it?
Well I'm pretty sure you can't develop the FPGA part in CVI. However in order to access the FPGA from a Windows application it needs to use the NI-RIO API. Technically it should be possible to access the NI-RIO API from CVI, since it is basically a DLL based C AP. LabVIEW uses internally this same API.
Obviously in order to use that API, NI would need to provide the documentation and C header files for that API. In case they don't or can't do that you would indeed have to create a LabVIEW wrapper and compile that into a DLL to be accessed by CVI. However LabVIEW does NOT support callback pointers, so you couldn't do that directly in LabVIEW. Instead you could use Windows events, calling in LabVIEW the apropriate Windows APIs to deal with them. Still most likely you will not be able to avoid some C wrapper on the LabVIEW side too, to provide some bindings to platform APIs. All in all a rather complicated setup, so I would in your case bug the NI repersentative about support for NI-RIO directly for CVI.
Message 9 of 14
(6,299 Views)
So now is there no way to complete this work ?
Message 10 of 14
(6,286 Views)
