02-22-2007 07:19 AM
02-22-2007 08:20 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.02-22-2007 08:32 AM
02-22-2007 09:02 AM
Some .dlls don't try to attach to the driver when loaded.
I've worked with both and unfortuately, I've not figured out a way around this problem.
You could possibly use the Conditional Disable structure around the dll calls so they would not be loaded unless you're in the runtime engine. But i've not tried this so I don't know for sure if it's possible.
Anyone??
Ed
