How can I call a VI in another VI?
I want to call b.VI in a.VI, how can i do?
For example,  there have one  CALL button in a.VI, when i push this button, the b.VI will be open and a.VI should be closed. And in b.VI, .there have a button name BACK, when i push this button, the b.vi will be closed and it back to a.VI.
pls do me a favor to give me some clue, thanks.
Message 1 of 9
(11,409 Views)
Using invoke node and reference you can do this. here i am posting an example for that. Copy both vi's to the same directory. a1 is the main vi
Message 2 of 9
(11,399 Views)
Thank you very much!
And i had try your sample vi,but i am so sorry to say that i can't open it in my Labview7,could you give me some samples in or below Lv7.
Thanks!
Message 3 of 9
(11,396 Views)
i have converted the vis to LabVIEW 7.
Message 4 of 9
(11,385 Views)
hello,
my task is same but i want to stop  the a.vi by calling b.vi ....i mean by application is running in a.vi and for closing tht application i have made b.vi. so how i will call b.vi to stop a.vi? please suggest.
Message 5 of 9
(10,367 Views)
(never mind)
Message 6 of 9
(10,218 Views)
@AjinkyaM wrote:
hello,
In my code, that would require b.vi to send a command to a.vi via a queue, user event, or notifier.  Can you provide some more of your architecture setup?  There are just way too many possibilities and roadblocks here to go any further without that foundation.
Message 7 of 9
(10,201 Views)
Tim, this is actually an old question and apparently continued here long ago.
Message 8 of 9
(10,192 Views)
*FACE PALM*
You were just trying to mess with me with your above reply, weren't you?
Message 9 of 9
(10,185 Views)
