09-09-2005 02:50 PM
09-09-2005 03:28 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
09-10-2005 07:52 AM
TiTou certainly pointed you down the right path... For a few more details, refer to my post to this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=141811
You could use the same technique, except instead of opening the clone's front panel, use the VI reference you have to it to poke it into a subpanel. Please note: I have never actually tried building a VI with more than one subpanel on its front panel, but it should work. Also you will not want to close the VI references because you will need them to stop the clones when you shutdown your application.
Mike...
10-17-2005 03:05 PM
10-28-2005 09:11 AM
