How can I change 3D graph Axis captions programmatically?
Hi All,
          I'm using a 3D graph to display results of a particular set of tests. I wish to change the caption on an axis depending on which test I'm running, e.g. the x-axis to change its caption from Deg C to Time (nS), there doesn't seem to be a property node to facillitate this. Could someone please point me in the right direction?
           Rgds,
            ds1
(4,462 Views)
Accepted by topic author ds_1
If you are using the CW 3d graph then see this thread where I illustrate how to change a property by using the CW 3d graph proprty screen as a guide.
If you are not using the CW 3d graph .... I can not help you.
Ben
(4,456 Views)
Hi ds_1,
you can use the "Axes properties" function as a starting point. Open the vi to see how to get the axis reference. Using this reference with a property node you can change the caption (and several other options too)!
(4,454 Views)
Thanks Guys!! Just had a little trouble locating the properties,
(4,419 Views)
