> Which Version of LV? V6.02 doesn't seem to have that property...
The property is the standard digital numeric properties. I don't think
it is version dependent, but I was looking at LV6.1.
Show the graph cursor legend. Popup on the numeric readout you want to
change. In 6.1, you can Create>> Property Node and it will be the
numeric property node. Ditto for the other elements in the cursor
legend. If you can't do this directly, and I know that some earlier
version put the graph's popup up when right clicking on the legend,
then you should be able to get the array's popup when you click on the
edge of the legend, and from there you can dig down to the numeric.
Greg McKaskle
