How can I change plot colours on a waveform chart
I am using a waveform chart with multiple plots (around ten).
I want to control the colours of the plot. I tried setting colours through Properties -> Plots
but nothing happened. In fact, the waveform chart doesn't respond to any plots settings.
I also tried changing colours programmatically using a property node with plot colour property
but that didn't have any effect either.
I checked Labview help. In Plots Page (Property Dialog Box) it says under the first bullet point:
  • Plots - Sets the plot you want to configure. Labview ignores this control unless you select Snap to Plot in the Snap to control.
Is that what the problem is about? What is Snap to control??? I couldn't find it anywhere.
Ivan
(3,249 Views)
if you click on the plot legend you can select color and the color box will apear to allow you to select your plots color.
Message Edited by Harold Timmis on 09-07-2009 02:15 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,239 Views)
And just incase you wanted to do it pragmatically here it is:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,235 Views)
Here it is multiple plots chart different colors:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,224 Views)
