How can I change the X axis on an XY graph? Trying to plot Frequency vs Gain
Hey guys, I think this is a super simple problem but I am having great difficulty with it for some reason.
I have an input signal (which is 4-20mA) which I feed through a filter. I have an output signal which is in Volts. I want to find the frequency response and bode plot of this system. I change the frequency based on the loop iteration (I increase the frequency value each time).
I convert the input signal to corresponding volts (multiply by 250). I then calculate my gain (20*log*Vout/Vin). This gain is now in dB.
If I am correct, I should just be able to plot the gain vs the frequency but I am not sure how. Each time I try plotting, its always against time (rather than a logarithmic frequency scale)
can anybody help me with this? I have attached the VI below. To run it however you need the FPGA code (should I upload that too? This just creates the sweeping 4-20ma sine wave)
Thank you!
Message 1 of 8
(4,575 Views)
Further, I just want to be able to plot the changing frequency with the Gain to get the plot. But I cant graph the frequency on the X axis and Gain on the Y axis.
Message 2 of 8
(4,574 Views)
Try the LabVIEW Help and search for XY Graph.
Message 3 of 8
(4,535 Views)
Thanks, I hadn't thought of that before.. Smiley LOL
Was the first thing I had done. I think part of my problem comes down to my timing and reading data sets, still looking.
Message 4 of 8
(4,510 Views)
Which part of that help document discussed how to change their data to a logarithmic representation?  Finding "XY Graph" wasn't helpful here.
OP, I forget which graphs have the right-click property to view the axis logarithmic.  Take a look at a graph and the xy graph.  If you can't find it on either, I'll check when I'm by a PC with LV installed
Message 5 of 8
(4,505 Views)
Remember that the word "time" is just the default label for the x-axis.  You can change it to whatever you want.
Message 6 of 8
(4,497 Views)
Hi guys, just an updated. I was looking at the problem at an incorrect angle. I needed to sample the peak to peak voltages for both in and out (after sampling for X seconds) and then write both these arrays into an XY graph via bundling. I had it inherently wrong.
The log scale is a property of the graph which you can get to by the front panel (right click)
Message 7 of 8
(4,494 Views)
Hello Muri,
can you share the vi with the sollution please because i have the same problem !
Message 8 of 8
(4,456 Views)
