How can I change the sequence of images I imported into Vision Assistant?
I have several large folders of images I pulled from a framegrabber. Each has between 300-500 .bmp images which are named 0, 1, 2, 3, ... , 365.  The problem is that when I use Vision Assistant to open the images it opens them out of order.  Ex: 1, 10, 100, 101, 102, ..., 11, 110, 111, ..., 12, 120, 121, ...
What is even more frustrating is that there doesn't seem to be a way to reorder the pictures, nor do I think I want to spend the time to do this for the 16 folders of images I am working with.
Thoughts... Ideas?
(3,258 Views)
would request to repost on Machine Vision Forums for effective Results.
http://forums.ni.com/ni/board?board.id=200
Sundar.
(3,247 Views)
Duplicate post: accepted solution found here: http://forums.ni.com/ni/board/message?board.id=200&message.id=23510#M23510
Marti C
NI Medical
(3,226 Views)
Really?  A duplicate post? No way!!! Who posted it?
(3,218 Views)
Hi WuTang4eva,
The duplicate post link was added to direct users to the accepted solution.
(3,199 Views)
