How can I change the step size of a control and simulation loop dynamically?
I would like the step size of the control and simulation loop to change based on the simulation time. I would like the step size to be a certain value for the first 10 seconds and then change to a different value for the rest of the simulation. Is this possible?
(3,539 Views)
Please, could you better explain us what you mean with "step size of a control"?
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(3,538 Views)
I'm talking about a specific feature in Labview, the ''control and simulation loop''. See http://zone.ni.com/reference/en-XX/help/371894F-01/lvsim/sim_simulation_loop/ for reference.
(3,532 Views)
Sorry but in that case I can't help.
Actually I don't have enugh experience on the Control & Simulation pack...
Ricky
(3,527 Views)
The first thing I would do is to try  to understand what all the terminals on the left side refer to.
For the description of any Simulation Parameters on a Control & Simulation Loop, start by double-clicking the Input Node.  Then, with the context help (<Ctrl+h>) enabled you can hover the mouse over any of the parameters and a description of that parameter will be shown in the context help.
(3,504 Views)
(3,503 Views)
