Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I change voltage level for FPGA module from 3.3V to 1.4V?
snehal24
Member
07-02-2008
01:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am using LabVIEW 8.5 and the FPGA Module NI PXI 7813R.
The volatge level for FPGA module is 0 to 3.3V. I need to use it with a hardware having 0 to 1.4V as the volatge level. Is there a good method to do this kind of level shifting?
Thanks.
0
Kudos
Message
1
of 2
(2,597 Views)
Reply
Re: How can I change voltage level for FPGA module from 3.3V to 1.4V?
Jeremy_B
NI Employee (retired)
07-07-2008
02:59 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi snehal24,
There are a variety of dual-supply bus transceivers on the market that can perform level shifting. Here's a good example:
http://focus.ti.com/lit/ds/symlink/sn74avc8t245.pdf
Jeremy_B
Kudos
Message
2
of 2
(2,561 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
