How can I check the open-mode of an opened file from the file refNum?
Especially whether a file is opened as read-only or write-only? I haven't found any VI in the panel with file VIs.
Thanks for any hints!
(2,542 Views)
Check this post. Probably you can use a kernel.dll call.
http://forums.ni.com/t5/LabVIEW/file-date-created/m-p/109836
(2,524 Views)
