09-25-2007 03:24 PM
09-25-2007 04:26 PM
What other software do you have installed, specifically which version of National Instruments NIDAQ driver and do you have National Instruments' Measurement and Automation Explorer (a.k.a "MAX"). With MAX if it was the version that was installed when the card was still working, you should be able to see the card in MAX's list and if so actually exercise it.
09-25-2007 08:16 PM
09-26-2007 10:13 AM
09-26-2007 10:26 AM
JohnSimon:
look under National Instruments-> MAX
if it is not installed it comes with the installation CD in the card.
Dennis, You are right, it will not work with MAX 7. to my recall, 6.9 was the latest it still worked with.
Note: John do not attempt to install a newer version of LAbview or MAX, without taking great care. newer versions will not work, and you will have trouble to reinstall older versions of MAX. so if you install new labview version, be carefull to uncheck the installation of MAX.
That said, the PCI 1200 is old, but very good.
