How can I compare more than two VIs at a same time in labview 2009
How can I compare more than two VIs at the same time. I am an Lab Engineer I have to check assignments submitted by students and I want to know how many of them are copied from each other. Labview compare VI can only compare two VI at a time while I want to check about 30 VIs at same time.
(2,326 Views)
I'm not aware of a tool to compare multiple VIs.  If you don't find anything, consider posting this to the LabVIEW Idea Exchange to expose this idea directly to NI R&D.
Thanks!
- Greg J
(2,291 Views)
