How can I connect "Get Date/Time String.vi" to "Write To Spreadsheet File.vi" ?
How can I connect "Get Date/Time String.vi" to "Write To Spreadsheet File.vi" ?  I want to write 05/06/2008 to spreadsheet for example. I tried many conversions in vain. I am using LabVIEW 8.0 now.
(3,810 Views)
Trying to fit a square into a circle? That VI uses a 1D/2D array of numbers, so why are you trying to feed a date?
I suppose you can do this:
If that actually means anything.
Message Edited by smercurio_fc on 05-06-2008 05:15 PM
(3,805 Views)
I want to store not only data of measurement system, but also date, time, commment, etc to one excel file.
Thank you for your advice. I tried what you propose, but it did not work. I attached the image of the error message.
(3,788 Views)
Hi Pikaichi,
right click on the "Write To Spreadsheet File.vi" select, select type -> "string" or "automatic". Smiley Happy
Mike
(3,770 Views)
Hi Mike
Thank you for your advice but no function of selecting "string" or "automatic" on LabVIEW 8.0.
I found that no problem connecting two vis on other PC installed LabVIEW 8.2. So I installed LabVIEW 8.2 on my PC, too, and now have no problem connecting these two vis.
Thank you.
(3,736 Views)
The ability to adapt the Write to Spreadsheet File function was introduced in 8.2. In 8.0 it was a single variant, which was to accept a 2D array of doubles. As with earlier version, this basically required one to create a copy of it and change it to use strings. Since you've updated to 8.2 you don't have to do this. Smiley Wink
(3,710 Views)
That proves it. Thank you.
(3,676 Views)
