How can I control a LabView VI using a C++ script/program?
I am a developer of a satellite communications system that is being used in
a satellite project I am working on at the University of Colorado - Boulder.
The project is called 3CS. We have built a simple LabView program that uses
some of the server routines to transfer data via TCP/IP protocol. The basic
VI initializes the radio hardware at the site the satellite is currently
over and then opens a data stream. The data is then downloaded back to our
servers via secure VPN. My question is this: How can I control a VI using
a language like C++ to execute certain parts of the VI. I basically have a
VI that listens for radio packets. My program then strips off the satellite
radio ID and protocol information
. I need to get this information into the
VI remotely through a C++ script. Any help would be greatly appreciated.
Sincerely,
Ryan R. Fligg
Colorado Space Grant College
Electrical and Computer Engineering
(3,026 Views)
Hello fellow Boulderite,
The easiest way would probably be to use the application builder to create a DLL from the VI. The other option is to use the LabVIEW ActiveX interface. There are some examples of using C++ to control LabVIEW in the example library of the NI Developer Zone.
(3,026 Views)
