How can I convert ANSI encoding to UTF-8 encoding
Hi,everybody
I want to convert ANSI encoding to UTF-8 encoding, which is used in XML doc display.How can I do it in LabVIEW?
shuiTuan
(15,486 Views)
You might want to look at the simple ANSI -> Unicode - and Unicode -> ANSI example in the LAVA Code Repository (link)
(15,450 Views)
Phillip, can you upload example to another sharing? Registration at LAVA have closed and link doesn't work.
(14,899 Views)
For reading (and writing) UTF-8 encoded files and texts see the VI attached to this message:
http://forums.ni.com/t5/LabVIEW/undocumented-function-quot-text-to-utf-8-quot/m-p/1034616#M460673
Greetings,
shb
(14,203 Views)
