How can I convert a Waveform to a String-Format?
I write with "SQL-Execute.vi" datas to an Access-file. The "SQL-Execute.vi" needs a statement in String Format. And that is my problem. My source-datas (that I want to save to Access) are Waveforms. How can I convert the Waveform datas to a String Format?
Thanks for help!
(3,079 Views)
Wire the waveform to the Get waveform componants function...from that you get t0, delta t and the sample values. Now you can generate whatever string you want based on that information...
You could e.g. wire the Y array to a for-loop in which you calculate the time of each sample by taking t0 and adding delta t multiplied with the array index, then you could convert the Y value and the time to strings using the seconds to time string and number to fractional string functions...etc etc...
(3,079 Views)
