How can I convert a double into a string
I have a knob control (double) which i use to control a voltage level. I also need that value to send a command. The command is a concatenation of the character "V" and the value indicated by the knob.
Can somebody tell me how I can convert the knob value to a string so that i can perform a concatenation.
(3,158 Views)
Use Numeric text.text property (or)
Number To Fractional String function from string ->string/number conversion in function palette.
-Kumar B
(3,157 Views)
Use the Format Into String Funtion. You don't concantanate anything.
Message Edited by Dennis Knutson on 04-06-2007 07:06 AM
(3,147 Views)
