How can I convert a string of hex values to a hex format string programatically?
Is there a way to convert a string of the following format:
1400010107070D0305006A01 ........           ("Normal display" string)
programatically to:
1400 0101 0707 0D03 05006A01 ..........      ("Hex display" striing)
I need to do this in order to calculate a CRC16 value.
See attached VIs
Thank you.
Message 1 of 21
(5,862 Views)
Hi chuck,
1) search the forum, this has been asked a lot of times before
or
2) make a loop, get 2 chars from the string, convert to U8 number (by hex string to number),  convert the resulting U8 array to string (by U8 array to string function)
Message 2 of 21
(5,856 Views)
You can iterate over the string and use the String to Hex VI. If you work with two bytes of the string at a time you can get a U8 array of the desired binary values. Then when you are complete you can either work with the byte array of convert it back to a string using Byte Array to String.
EDIT: GerdW typed faster than I did.
Message Edited by Mark Yedinak on 03-18-2010 02:55 PM
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 21
(5,853 Views)
My problem is that the orignal string is in hex, but not hex format.
Message 4 of 21
(5,849 Views)
Hi chuck,
your problem is you did not try what we told you to do Smiley Wink
Message 5 of 21
(5,843 Views)
Accepted by topic author chuck72352
Here is exactly what we suggested.
Message Edited by Mark Yedinak on 03-18-2010 03:09 PM
Mark Yedinak
LabVIEW Champion
Message 6 of 21
(5,841 Views)
I was much kinder than you since I posted the solution. I was tempted to reply the same as you though. 😄
Mark Yedinak
LabVIEW Champion
Message 7 of 21
(5,839 Views)
Hi Mark,
I'm a grumpy old man Smiley Wink
Message 8 of 21
(5,836 Views)
Thank you, very impressive!
Message 9 of 21
(5,826 Views)
Just for the heck of it.
Message 10 of 21
(5,818 Views)
