How can I convert single element array to integer
I have extracted a single element/character from a string using "String Subset Function". I want to convert this to a number eg U8.
The output from "String Subset Function" produces a 1 character string. If I convert it to U8 it produces an array of U8 with one element.
How can I convert it to a non-array variable?
Many thanks
Andy
PS originally posted in wrong Forum. Apologies.
(4,816 Views)
Accepted by topic author AndyNC
Hope this helps!
Christian
(4,811 Views)
Andy,
Post a snippet of your code if Christians answer is not what you are looking for.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,810 Views)
If you want to interpret the text to a number you'll need to use the Decimal String to Number and similar from a sub-pallete in string-pallette.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,806 Views)
Christian's answer was perfect.
Many Thanks
Andy
(4,799 Views)
