How can I creat a control button that will allow the vi to run?
Instead of pressing the run button, I want to creat my own run button that will allow my vi to run.
Any idea?
Thank you
(2,730 Views)
First you need to set the VI to Run When Opened (VI Properties>Execution). Then you create a front panel Boolean. On the diagram what you need to do is have some sort of idle state where nothing is done until the Boolean is pressed. It could be a separate while loop that doesn't exit until the Boolean is pressed, an Event Structure, or as part of a state machine. Look at the shippings examples Queued Message Handler, New Event Handler, Using Buttons for Options to name just a few.
(2,730 Views)
Put the any Boolean button which you feel right or it is atleast in shape you want.
Right click this button -> Advanced -> Customize...
Then a new front panel will open. Here you can shape or modify the button. Save it & replace your original control with the modified one.
Hope this works.
Best Regards,
Nirmal Sharma
India
(2,730 Views)
