How can I create a Development Distribution Programatically?
I want to use the Save with Options Dialog in a LabView Program.
My LabVIEW Program can save the Whole Hierarchy of the Top-Level vi with all needed SubVis, but I need the Controls also, otherwise
my LabVIEW Program can not run.
Is there a possibility to use the Option "Save for Application Distribution" programatically?
Thanks for help.
(2,876 Views)
hi
2 suggestions:
- change all of your controls to TypeDefs or Strict TypeDefs. Then the control will appear in the list of the callees of a vi.
- add a Custom Runtime Menu to your App. Add the Application Item "Save with Options.." to the RTM. By doing so the Dialog Appears when the menu item has been selected.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,864 Views)
