How can I create a boolean oscillator in Labview?
I have a booloean indicator that I would like to go back and forth between 0 and 1 at a constant rate (360 Hz). To clarify, I would like the indicator to indicate true 360 times every second at equally spaced intervals.
(3,749 Views)
Accepted by topic author Laura121
Something like this?
Are you trying to update an indicator or is hardware involved?  You are not going to get a reliable 360Hz toggle with Windows timing.  You can easily with the right hardware.
(3,741 Views)
I saw your answer. I want to build oscillator in LabVIEW too. But can you give me explanation about the Indicator you use (View as Icon).
I am new in LabVIEW.
What I want to do is to generate a signal square or triangular signal to trigger a Led. I use USB board interface for that. It is running but I need to control my Led with Oscillator.
(3,670 Views)
That indicator was just something to show that the value is toggling.  You can just replace that indicator with a write to your digital line.
(3,653 Views)
