How can I create a buffer, array or pipeline that stores the last 5000 dates of a voltage measurement with PCI6036 & SCXI1104C and continously drops the last date and inserts the latest date (scanrate 200 or 2000Hz)?
I develope a porgramm for continious monitoring. If the voltage of a channel exceeds or is lower than the upper or lower limit of tolerance the actual date must be stored and additionally the dates being stored 10sec before and after this event. Can somebody give some advice how to create the buffer to keep the dates 10s before the error event? Thank U.
(2,495 Views)
I've written you a quick array buffer vi. I'm not sure if it'll be fast enough though.. Try it and see! I've used the loop numbers in my array, but i'm sure you can feed in the dates instead.
(2,495 Views)
