How can I create a toolbar
How can I create a tool bar with a functions defined by the user .? For example on the case of explorer on windows there exists a tool bar which can capable to opt tools which been pre determined .How can this be make possible in my application using Labview ?
(3,208 Views)
Hi
You could customize buttons (import a picture for true and false state). These can be aligned in the upper area of your vi and handled as normal buttons.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,197 Views)
    here importing picture is not the problem .I want a menu (pop up menu)with one option been fixes after selecting any of the menu items .
Is it any option to do so?
If been please help me.
(3,169 Views)
Well, a pop up menu is not like a tool bar, but you can find one example here.
In general, if you want the menu to open more screens, you will need to create and call those as subVIs.
If this still doesn't help you, I suggest you explain your problem in more detail, and maybe post a screenshot of the what you want to get (no BMPs, please).
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
(3,153 Views)
