How can I create an installer?
Hi!
I am working with LabVIEW Version 8.6.1.
After I have built an Application (exe) I would like to create an installer. Therfore I open the window "my installer properties" in my Project.
After I got the "product information" I go ahead to "source files". First question: Which files must be include in the "destination view" on the right site of the window???
The "builds" file???
If I do this and go ahead with "additional installers" I select "NI LabVIEW Run-Time Engine 8.6.1". After that I click the bottom "build".
The build status open. Than I get a default:
build errors:
the build was unsuccessful
The following file(s) are not found on the system:
 I think it has to do with the source files which I have to include. But I do not now which one!!!
Can somebody help me???
Marc
(3,749 Views)
Well, you have to select the actual application that you created. What else are you going to install? Have you checked the LabVIEW documentation. It's pretty self-explanatory in there.
(3,736 Views)
You will indeed need to create an executable from your project first and then add this to your installer build.
Here are a few links on how to create an installer, could be very useful for your issue:
Distributing applications with application builder:
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
Including additional installers:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N8tSAE&l=en-US
Missing distribution:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OIGSA2&l=en-US
AdamF
Adam
Academic Product Manager
National Intruments
(3,717 Views)
thanks for your replies!!!
I am afraid, there is still an default. See picture! How can I get all distributions I need???
 I hope you can read it!!!
(3,692 Views)
Hallo MarcQ,
Genau, ich verstehe.  It is asking you for a 'Needed Distribution=Notwendige Distributionen.'  You will need to say 'Ja' and point the prompt tothe LabVIEW 8.6.1, Disk that you installed LabVIEW 8.6.1 from.
All of this information is taken from Link 3 that I gave you:
Check it out, and you will find the exact solution to the issue about half-way through the issue.  You might need to copy the LabVIEW CD image to your hard-drive or create a local cache for the files.  Anyway, read the article, it will explain everything.
Best wishes,
AdamF
Adam
National Intruments
(3,669 Views)
