How can I create flat sequence structure and add subvi with true or false over another flat seq.?
How can I create flat seq. and add one colum with falseSub VI and True Sub VI?
(3,424 Views)
Your question makes no sense because, in Flat Sequence, there are one or more frames, which execute sequentially.
Don't you want to explore (and use) Case Structure...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,416 Views)
Yes I know, but its very difficult to tell what I mean, But I wanna one flat seq that involve my prog and one subvi with true and false?
(3,406 Views)
Hi q8,
just draw such a flat sequence as you did on the sheet of paper...
But wait, we have DATAFLOW here! Use an error wire to sequence your "my prog" with those "subVI with true and false". This way you will learn to write better LabVIEW programs...
(3,393 Views)
You need a state machine built upon a case structure.
PaulG.
Retired
(3,392 Views)
Accepted by topic author Labviewq8
Is this should be the flow diagram:
Flow Diagram
(3,375 Views)
