How can I create use producer consumer architecture using typedef clusters?
Hii crossrulz..,
 I have implemented that also, Its working fine. But I want time stamping to be recorded in a separate channel. And also I want to create and record files in some instants say 15 seconds.
Message 21 of 22
(1,178 Views)
hello jeff,
Please correct me if I am wrong anywhere...
Exactly! That's why i started reading 100k samples at a time which would increase the reading rate of data, so that buffer will not fill up and it would not give that error. But after doing this chnage also buffer is getting overflow.
Message 22 of 22
(1,176 Views)
