How can I customize the Column Headers of the TABLE control/indicator in LabVIEW ?
I need to customize the TABLE control/indicator in the LabVIEW as the same shape of the table in the LabWindows CVI or the DBgrid of the Borland Delphi. Where can I modify the color and shape of the Column Headers and the Row Headers. See the example below.
Cleber
(6,365 Views)
Perhaps using a table property node then format the headers on the front panel using the text settings.
(6,347 Views)
Hi Cleber
I don't think it's possible to alter the column and row header colours using property nodes. However you can set the colours and sizes on the first row and column and treat these as your headers.
See attachment.
Neil
(6,339 Views)
It's cool! Thanks a milion guys...
Cleber
(6,329 Views)
