01-27-2009 08:59 AM
I have to communicate through the PC's RS-232 interface with a microprocessor board. I am using the "Advanced Serial Write and Read.vi" out of the LabVIEW examples and it works on principle.
My problem is the termination character: It looks like I just can set one termination character, EITHER 0xA (so LF / newline) OR 0xD (CR / carriage return), but I have the need to react on various termination characters like "<CR> <LF> <CR> <LF> OK <CR> <LF>" or "<CR> <LF> <LF>"; which I would like to set in a control (this VI will be used in a TestStand sequence).
Is there a way to do that, so that I can set wichever termination character(s) I need? The property node in "VISA configure serial port" just accepts an unsigned integer, nothing else. Sure I can get it running with the timeout - but this is not very nice and extends testing time unnecessarily.
Thanks & Regards!
Solved! Go to Solution.
01-27-2009 09:28 AM
Hi gedi,
switch off the "normal" termination character and add what ever you need to the end of your string.
Mike
01-27-2009 10:20 AM
01-28-2009 01:36 AM
