How can I design an arithmometer?
In my VI , I need an arithmometer to count the times of True or False from a comparison. As the true continuously appear three times , the data will be recorded , but if one false appear , the times will to be zero . The comparison will be repeated until the times to be 3 . Then how can I design this arithmometer?
Thanks a lot !
(2,771 Views)
Hello:
I'm not sure if I understood exactly what you need. I've made a simple VI that does the following:
- Compares two numbers whenever you press the Compare button
- If the comparison is true, it increments a counter by one.
- If three straight comparisons are true, it shows a dialog (this is a dummy behavior, do what you need here), and resets the count
- Whenever a comparison is false, it resets the count
I hope this helps you to finish your program
If you need further asistance don't hesitate to post.
Robst
Robst - CLD
Using LabVIEW since version 7.0
(2,744 Views)
Is the comparision a hardward you mentioned? What kind of signal does it output? The digitial or analog? If it's hardware, you can use the DAQ device(AI or DI) to capture the siganl. And execute the algorithm in software.
(2,729 Views)
