How can I develop a ring-control with sub-menus?
Hello there:
Thanks for your post, this is the information I have been locking for,  Could you help me to find the information that you used? I tried to open the links, but the apparienly they had fallen.
Thanks in advance.
Message 31 of 32
(1,008 Views)
There are many things in this thread, so you would have to be more specific. In any case, I don't think you need any of the old links, as pretty much everything from back then can be done inside LV or with the VIs attached in this thread. If the data in this thread doesn't help you, you should start a new one and explain exactly what you're trying to do, what you did already and what the problem is.
___________________
Try to take over the world!
Message 32 of 32
(952 Views)
