How can I disable an frequent update of chart contents?
I have a vi with a xy graph (x = time) and lots of data in there (aprox. 6000 values).
I do not update the values very often, maybe once in a second, to not to stress the cpu too much, but I have noticed, that the chart updates much more often and that causes a high cpu load. If I cover the VI with another window druing run time, the cpu load drops to almost 0.
Can I set how often a chart updates? Where?
Johannes
LabVIEW 7.1
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(2,704 Views)
Oh, I just found out, that my problem comes from somewhere else.
I set the xscale minimum and maximum every cycle according to the current time. If I reduce this xscale updates, the cpu time drops drastically 🙂
Greetings Johannes
(2,702 Views)
