I would like to translate the User Interface of my application to French, Italian, Spanish, German and Portuguese.
When I put special characters in the import string file they showed up as ? (question mark)
The import strings file includes the following parameters for each string: font, text, size and style. (but no field for script)
In order to use a unicode font such as Arial I need to select a french script. But this option is not supported bu LabView (As far as I saw)
A) Is there a font which is directly German/ French etc and not regula font + script parameter?
B) Are there another required step
s for special characters support? (When I put speciual characters in the import string file the showed up as ? question mark)
