I am using LV 8.2. I have attached a screen shot. One display shows the attributes in the order I want because I added numbers and a character to the name of the attribute. The other var display shows the normal way LV displays the attributes. I use the variant and the attributes to reconstruct the string that you see as the input. However, the order does not stay consistant to the output which may break things down the road.
I just want to know if there is a settable property on the variant attributes to display them as entered rather than alphabetically. I have a work around but I would rather know if it is settable through LV instead of adding my numbers and char and stripping them off at the back.
